12-01-2008 04:54 PM - edited 07-03-2021 04:50 PM
I've been trying to upgrade the boot image of my WLC4402-12, even following the intructions in the Cisco documentation. The image is correctly transferred from the TFTP but when I reboot the WLC I just see the same old boot image.
Please see the attached picture. Y try the 5.2 main imagen as well as the boot or ER image.
Solved! Go to Solution.
12-01-2008 08:07 PM
Just remember, 4.2.112 is the last bootloder update.
12-01-2008 06:40 PM
That is a cosmetic bug on the wlc. As long as you didn't error during the upgrade you will be fine. 4.2.112.0 ER.aes file is the last ER file to contain a bootloader.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805f381f.shtml
12-01-2008 08:04 PM
Ok,so it must be OK, thank you
12-01-2008 08:07 PM
