CCVP / CCNA Voice
Dec 1st, 2008
Hi Cisco,
I just got my CCNA 640-802 and I would like to get the CCVP without doing the CCNA VOICE. I see that it's possible to do it without the CCNA Voice if you do it before june 09. Now, I'm asking me as CCVP is 5 exam, if I do like at least one exam ( one of 5 ) before june. Is it possible to get the other 4 exam after june without getting the CCNA Voice
thanks a lot :)
tperrier Tue, 12/02/2008 - 00:56
  • Silver, 250 points or more
Now that would be too easy, wouldn't it? ;)
philippe.cousineau Wed, 12/03/2008 - 04:56
Well.. I guess that just CCVP is far from easy
but I understand your answer :)
thanks
Naveen Raj Janardhan Fri, 12/05/2008 - 12:15
Philippe,
From what I Understand, CCVP certification is bundled with 5 exams. Only if all these 5 exams are passed, we get certified as a CCVP.
To answer your question you must have passed all the 5 exams before June 24th 2009 to qualify as a CCVP. Say for instance, you are done with 4 exams before 24th June and take the 5th exam after 24th, then you MUST take CCNA Voice in order to qualify again as a CCVP.
It does definitely sound tedious, but certainly possible. All the very best!!
Please rate helpful posts.
Naveen
Manish Prasad Mon, 12/22/2008 - 14:55
Hi Naveen,
It means that after 24th of june 2009 the papers which i have passed in ccvp need not to clear again if i fail to complete the whole series.
Prasad
Chris Deren Tue, 12/23/2008 - 07:05
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
No, all it means is that you will need to pass the CCNA-Voice to get CCVP on top of the 5 exams.
HTH,
Chris
