ACS 4.2 replication issue
Dec 1st, 2008
We recently upgraded to ACS 4.2. All works perfectly except for replication. I now receive an error
ACS Internal Database Replication Errors
1.To disable receiving of EAP-FAST replication component, "EAP-FAST master server" must be enabled on "Global Authentication Setup" page
We are not using EAP-FAST and it doen't appear to be enabled. EAP-FAST is not checked to replicate.
pvanvuuren Mon, 12/01/2008 - 23:22
  • Bronze, 100 points or more
Check if the two ACS version are exactly the same. e.g. 4.2(0) Build 124.
You can try checking if EAP-FAST master server is checked too. Its at the bottom of the page when you click on EAP-FAST configuration link at "Global Authentication"
danhosking Mon, 12/08/2008 - 16:10
I looked at that when I first got the issue. It saya that the server is Master. If I tick the box nothing changes and when I go back to that "Global Authentication" page the box is no longer ticked. The issue is the same on both the Primary Server and the Backup Server.
