CSS always points to 1 server
Dec 1st, 2008
please see my CSS configure, it is a basic config, but CSS always divert the traffic to 10.122.70.13, even it is down, while 10.122.70.14 untouched:
!************************* INTERFACE *************************
interface 1/1
trunk
vlan 25
vlan 70
interface 1/2
isc-port-one
interface 2/1
trunk
vlan 25
vlan 70
!************************** CIRCUIT **************************
circuit VLAN25
description "Management VLAN 25"
ip address 10.122.25.37 255.255.255.0
circuit VLAN70
ip address 10.122.70.30 255.255.255.0
!************************** SERVICE **************************
service Server13
ip address 10.122.70.13
port 514
protocol udp
active
service Server14
ip address 10.122.70.14
port 514
protocol udp
active
!*************************** OWNER ***************************
owner L3_Owner
content L3_Rule_syslog
add service Server13
add service Server14
vip address 10.122.70.15
balance leastconn
protocol udp
port 514
advanced-balance sticky-srcip
active
!*************************** GROUP ***************************
group syslog
add destination service Server13
add destination service Server14
active
CSS11503# sh service summary
Service Name State Conn Weight Avg State
Load Transitions
Server13 Alive 0 1 2 10
Server14 Alive 0 1 2 8
CSS11503# sh keepalive-summary
Keepalives:
AUTO_nexthop00002 State: Alive 10.122.25.1
AUTO_Server13 State: Alive 10.122.70.13
AUTO_Server14 State: Alive 10.122.70.14
CSS11503# sh flows
Src Address SPort Dst Address DPort NAT Dst Address Prt InPort OutPort
10.122.48.41 49 10.122.25.37 11219 0.0.0.0 TCP 2/1-25 Ipv4
10.122.70.2 2333 10.122.70.15 514 10.122.70.13 UDP 1/1-70 1/1-70
10.122.23.18 514 10.122.70.15 514 10.122.70.13 UDP 1/1-70 1/1-70
10.122.23.13 2307 10.122.70.15 514 10.122.70.13 UDP 1/1-70 1/1-70
10.122.23.17 514 10.122.70.15 514 10.122.70.13 UDP 1/1-70 1/1-70
Can someone let me know why?
thanks
Overall Rating: 5 (1 ratings)
Syed Iftekhar Ahmed Mon, 12/01/2008 - 20:15
I suspect its because of Source IP based stickiness. Are you hitting the VIP using the same source ip (e.g users are using a proxy servers using proxy's IP as source).
Syed Iftekhar Ahmed
shibindong Mon, 12/01/2008 - 20:26
I don't think it is the problem, even I suspend the server Server13, or shutdown server with 10.122.70.13, it still points to it.
after i remove the sticky srcip configure, not changed
Gilles Dufour Tue, 12/02/2008 - 05:00
what ever you do won't affect active connections.
You may have to kill all connections.
Gilles.
shibindong Tue, 12/02/2008 - 18:35
thanks, Gilles. after i restart the CSS I saw traffic been load balanced...
if there any command to restart the service? I cannot every time restart CSS. thanks...
