Exporting and Importing a Cisco ACS DB
Dec 1st, 2008
Hi All
We are going thru an upgrade, and are moving from our current platform, Cisco ACS 3.3 to a new one, Cisco ACS 4.2.
My question is, how do i export the user database from 3.3 and import into 4.2? I couldn't find any reference to CSUTIL.EXE in the 4.2 user guide.
We need to be able to export all the account data, including the static IP Address assigned.
Any thoughts?
Cheers
Ben
mchin345 Fri, 12/05/2008 - 14:10
  • Silver, 250 points or more
To import a text file into the CiscoSecure user database to add new users to the database or modify users' authentication information. When you install Cisco Secure ACS in the default location, CSUtil is located in the following directory:
C:\Program Files\CiscoSecure ACS v2.6\Utils
You can also perform these and similar tasks through the Cisco Secure ACS hypertext markup language (HTML) interface, using the ACS System Backup, ACS System Restore, Database Replication, and RDBMS Synchronization features
For export & Import ACS DB click this link.
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_user_guide_chapter09186a008007e689.html
