[RTMT-ALERT] DirectoryConnectionFailed - CM 4.1(3)SR8
Dec 1st, 2008
continually getting alert after configuring RTMT relating to Directory Connection even though everything appears ok.
Directory connection failed .
Monitored precanned object has value of 0.
my callmanager cluster is integrated into our active directory so not using DC directory and i am wondering if this
alert relates only to DC directory??
If it does i will disable it, however, if it also monitors the connection to active directory then i want to leave it enabled.
Everything looks ok on the callmanagers.
