ASA Active/Standby - now cant connect to them?
Dec 1st, 2008
Hi after having an issue with my ASA 5520 Active/Standby i had disabled the failover on both devices.
I then re-enabled the failover by issuing the failover command on the primary device first then the failover command on the second device.
sh failover on the primary:
Failover On
Failover unit Primary
Failover LAN Interface: failover Management0/0 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 2 of 250 maximum
Version: Ours 8.0(3), Mate 8.0(3)
Last Failover at: 13:30:37 ACDT Nov 25 2008
This host: Primary - Active
Active time: 619894 (sec)
slot 0: ASA5520 hw/sw rev (2.0/8.0(3)) status (Up Sys)
Interface inside (##.##.231.000): Normal
Interface outside (##.###.##.##): Normal
Interface Liift-DMZ-E (##.##.###.###): Normal (Not-Monitored)
Interface Mesant-DMZ-E (##.##.###.###): Normal (Not-Monitored)
Interface Service-DMZ-E (##.##.###.###): Normal (Not-Monitored)
slot 1: ASA-SSM-10 hw/sw rev (1.0/6.1(1)E2) status (Up/Up)
IPS, 6.1(1)E2, Up
Other host: Secondary - Standby Ready
Active time: 0 (sec)
Interface inside (##.##.231.888): Normal
IPS, 6.1(1)E2, Up
sh failover on the secondary:
sh fail
Failover On
Failover unit Secondary
Interface Policy 1
Last Failover at: 16:21:09 ACDT Dec 2 2008
This host: Secondary - Standby Ready
Interface inside (##.##.231.000): Normal (Waiting)
Interface outside (##.##.###.##): Normal (Waiting)
IPS, 6.1(1)E2, Up
Other host: Primary - Active
Active time: 616143 (sec)
Interface inside (##.##.231.888): Normal (Waiting)
Interface outside (##.###.##.##): Normal (Waiting)
IPS, 6.1(1)E2, Up
so looks good.
But since i enabled failover on the secondary unit, i can no loner get SSH or ASDM connection (444) to either of these devices from my pc? i can ping directly connnected networks from both devices and can confirm interfaces are up via console. But i cant management connection to them via IP any more.
anyone ever seen this issue?
Davy Ad Tue, 12/02/2008 - 08:43
Hi Jason,
You said "i had disabled the failover on both devices".
->> You do not have to disable both device
->> Disable only the Active , then check again.
DAK
its-system Fri, 08/21/2009 - 03:35
"no http server enable" and "http server enable" will solve your ASDM-problem, but you need ssh or the console to do that.
julomban Fri, 08/28/2009 - 07:48
  • Bronze, 100 points or more
With the above commands should work, if that doesn't work you can try to regenerate the crypto keys and try again...
"crypto key generate rsa key"
