Giuseppe Larosa Tue, 12/02/2008 - 00:46
  • Hall of Fame,
    Founding Member
Hello Sergej,
be aware that the mGRE tunnel creates a virtual flat topology.
You can use a dynamically learned public address on the exit physical interface where the tunnel is applied :
tunnel source FastEthernet0/0
this allows you to be independent of the actual ip address of FE0/0 that for example can be acquired via PPP IPCP if using PPPoE client feature for example.
the internal ip address of the tunnel instead can be manually configured in all scenarios: it is a private ip address that you manage.
Hope to help
Giuseppe
sergey.klusov Tue, 12/02/2008 - 00:52
I know all that myself.
But i don't want to keep track of all tunnel IP's, assigned to branch offices.
sergey.klusov Tue, 12/02/2008 - 01:06
Maybe there is some other way co connect branches, which might have dynamic external IP's to central office with OSPF support?
I've also tried l2tp, but OSPF and PPP are not good friends.
Giuseppe Larosa Tue, 12/02/2008 - 02:00
  • Hall of Fame,
    Founding Member
Hello Sergej,
DMPVPN is a powerful tool but this limitation is probably built-in.
I've never used it but Cisco has recently introduced a new framework called GETVPN
see
http://www.cisco.com/en/US/docs/solutions/Enterprise/Branch/srlgbrnt.pdf
It may be able to provide what you are looking for
Hope to help
Giuseppe
