central manager corrupted
Dec 2nd, 2008
Hi All,
I have a situation with my central manager. I have a project for about 200 branches and they purchased just one central manager. The problem now is that the central manager is corrupted. I cant configure it or even recover it because once i type anything, it comes out with the wrong characters instead. i cant log in or even set the bootflag to bypass the login detail, because what i type is not what shows on the screen. I have attached the loading sequence for any errors that it might be generating. I would like to know with this new 4.1.1 image, can i set one of the application accelerator with a transport license to become a central manager even though it does not have a central-manager license.
Also, what can be done to recover this box without sending it back to Cisco.
Regards.
ropethic Tue, 12/02/2008 - 03:22
  • Silver, 250 points or more
You can make another unit a Central manager by configuring it as CM
Step 1:
Configure WAAS Settings
Select device mode :
1.application-accelerator
2.central-manager
Enter your choice [1]: 2
This configuration takes effect after a reload.
Enable CMS automatically after reload (y/n) [y]: y
Step 2:
Configure network settings
Select interface to configure as management interface:
NO INTERFACE NAME STATUS IP ADDRESS NETMASK
1: GigabitEthernet 1/0 UP unassigned unassigned
2: GigabitEthernet 2/0 DOWN unassigned unassigned
Enter choice [1]: 1
I will take a look at the attached file.
dot10000000000 Tue, 12/02/2008 - 05:16
I know i can turn a device to a central-manager, I am actually concerned with how the licensing for a central-manager works and the license effect of turning an accelerator with transport license to a central-manager.
Regards.
steven-dunn Tue, 12/02/2008 - 15:22
Your customer should have purchased another CM. The WAE512-1G running version 4.1 is sized to manage upto 500 end devices but a second should be installed for redundancy.
I don't know the maximum for version 4.0.19.
Try the recscue CD ?
You may have to discuss this with your cisco rep, but from memory there are only two licences for version 4.1 even though the configurator shows three. A transport licence and an enterprise licence. You need the enterprise license to do application optimisation or CM function.
Steve
