converting Cat OS to IOS
Dec 2nd, 2008
I am looking to upgrade two WS-6509 switches ..the current image is bootflash:cat6000-sup2cvk8.8-4-2.bin
WS-X6K-SUP2-2GE and WS-F6K-MSFC2
I am looking to convert this to IOS, is there a tool that can do this or do I have to do the conversion line for line?
do I have to upgrade the ios on the MSFC as well?
appreciate the help...Thank You!
Overall Rating: 5 (1 ratings)
Jon Marshall Tue, 12/02/2008 - 03:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jay
Start with this document which covers upgrading the images. With native you do not have separate images on the SUP & MSFC, one image is used for the whole switch -
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml
Here is a link to a tool that can convert from CatOS to IOS -
www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a0080816fbc.shtml
I have never used it myself and i've read a few posts on these forums about it being better to do it by hand. If you do don't forget the "interface range .. " command under IOS which allows you to apply the same config to a range of interfaces, can be a real time saver.
Jon
archari Thu, 12/04/2008 - 15:36
  • Cisco Employee,
Yes the same instructions hold true.
