CiscoWorks Backup
Dec 2nd, 2008
I am unable to run a backup as my diskspace is to low.
Apparantly from the log file I have 23196244Kb of space and require 161795341Kb.
This seems like an extremely large backup file. Is there anyway to reduce the backup size significantly.
yjdabear Tue, 12/02/2008 - 07:04
I bet your single largest disk-eating directory is /var/adm/CSCOpx/files/rme/dcma/difffiles. You can verify that with "du -skr".
You can examine and delete those diff files older than NNN days with:
cd /var/adm/CSCOpx/files/rme/dcma/difffiles
find . -type f -mtime +NNN -print -exec ls -ltr '{}' \; | less
find . -type f -mtime +NNN -print -exec rm -r '{}' \;
mironduplessis Tue, 12/02/2008 - 08:07
I am running this on a windows platform. The size of the difffiles folder is only around 350MB. The entire CSCOpx directory is 105GB.
Is there somewhere else i should be looking.
yjdabear Tue, 12/02/2008 - 08:34
Assuming you're referring to /var/adm/CSCOpx (or the Windows equivalent), it depends on many factors such as how the Syslog Purge and Job Purge have been configured in RME. Since the backup doesn't include /var/adm/CSCOpx/logs, check out the "dcma" and "jobs" directories under /var/adm/CSCOpx/files/rme.
