1841 Router Performance
Dec 2nd, 2008
Hello All
I have been trying to dind this information and have not been able to find anything in the Cisco documentation. Hopefully someone here can help me.
Anyways, I am looking at purchasing an 1841 router for office but I need to make sure if can handle a large number of new connections per second and large number of concurrent connections. We only have a few people in the office, but run some programs that have large number of connections per second and concurrent connections. I have been looking around and could not find what the 1841, with a FW feature set, will support in terms of connections per second and concurrent connections. Does anyone know what these stats are?
Also, if I go with the 8-port switch module, does anyone know if you can assign each port of the switch to a separate vlan and do intra-vlan routing between ports on the module? I'm not sure if the switch shows up as one interface or if each port is a separate interface on the router allowing for different vlan's.
Thanks for the help
Overall Rating: 4 (1 ratings)
satish_zanjurne Tue, 12/02/2008 - 11:48
1.Cisco 1841 supports upto 800VPN Tunnels with AIM module.
2.HWIC-4ESW , HWIC-D-9ESW , you can assign ports to different vlans.
3.A total of 15 VLANs are supported by an EtherSwitch HWIC.
4.This is a pure L2 switch module , no intervlan routing between ports on the module.
5.It will show ech port as seprate interface on the router.
HTH..rate if helpful..
nickehunt Tue, 12/02/2008 - 11:54
Thanks for the help. I got the VPN tunnels for concurrent tunnels, but do you know the number of concurrent connections the router will support with the FW feature set?
nickehunt Wed, 12/03/2008 - 05:26
Thanks for the information, this was very helpful.
In terms of the switch module, do you know if you can assign virtual dot1q interfaces on the router for intra-vlan routing between vlans on the switch module?
Pravin Phadte Fri, 12/05/2008 - 06:00
I am soory but unable to understand what you want to do with virtual dat1Q interface.
i am sure you are aware that you can create a interface as a trunk on router and sub interface with dot1Q for intervlan routing for the vlans on the switch.
You need to have a physical interface to be connected mostly it would not be possible using virtual interface.
let us know what you want to do in you network design.
