mobility
Dec 2nd, 2008
Dear
if i have two controllers on different subnet and ONE SSID on different Subnet how can have roaming mobility between the two controller,some people recommended to use Mobility anchor but i dont know if true or what
Overall Rating: 5 (1 ratings)
gamccall Tue, 12/02/2008 - 07:41
  • Silver, 250 points or more
It works out of the box.
If a client associated with one controller associates to an AP on a different controller, the new controller will set up a tunnel to the original controller and pass all of the client's traffic through that tunner. The client keeps his same IP address.
The only configuration you have to do to make this work is make sure that both controllers are in the same mobility group.
Mobility Anchor is not necessary for this functionality. By default, a user's "home" controller is the first controller he associated to when he started his wireless session. If you want to force a certain group of clients to always use a specific controller as their "home" controller, regardless of where they first associated, you would use the Mobility Anchor feature for this. Usually, it's used to anchor guest traffic to a DMZ controller.
For more info, see the Mobility Groups FAQ here:
http://www.cisco.com/application/pdf/paws/107188/mobility_groups_faq.pdf
ahmedalshami Tue, 12/02/2008 - 21:20
thanks
I know this ,but my question if use different subnet and one SSID
controller 1 ------SSID=WARDA subnet =192.168.100.100/24
controller 2 ------SSID=WARDA subnet =192.168.200.100/24
And all controllers on one Mobility group
the roaming for data and voice will work
thanks again
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
