CNA Ver 5.4 Login
Dec 2nd, 2008
I'm running version 5.4. I want to know if there is a way to connect to a device using CNA in a read-only enviroment ?
I have user accounts created on the switches with access level 7. When you connect using CNA it says username and password for realm 15. Any help would be appreciated.
aghaznavi Mon, 12/08/2008 - 14:51
  • Silver, 250 points or more
Use the Connect window in Network Assistant to connect to a community or cluster
Step 1: From the Connect window, enter the IP address of the device.
For an existing community, select its name from the pull-down menu. For an existing cluster, select the IP address.
2. For HTTP and Access Mode options, click the Options button.
- In the HTTP protocol field, select HTTP or HTTPS. To communicate with a clusterered or a standalone device, use HTTPS (secure HTTP) instead of HTTP.
- Select an HTTP port. Use an HTTP port other than 80 on cluster command devices or standalone devices.
- Select an access mode. Read-only access mode is the default.
- Click OK to return to the Connect Window.
You can also use this window to connect to a new community. For instructions on how to use the Connect to a new community option to create a community.
Step 3: Step 2 Click Connect
When you click Connect, you are either connected to the community directly, or you are prompted for a username and password and then connected. When you connect to a cluster, Network Assistant asks if you want to convert the cluster to a community
For further information click this link.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_network_assistant/version5_4_1/quick/guide/English/install.html
