Air-AP1220B series
Dec 2nd, 2008
I am trying to set up this 1220B AP so I can browse to its configuration screen however I can't establish a connection even though I believe I have the AP and my PC configured correctly. Here are the settings:
AP Settings
IP SN manually set
PC directly connected to the AP through the ethernet port (cable confirmed to be good):
Even with these settings and a direct ethernet cable connection I cannot even Ping the AP.
I did a show run and the configuration is correct. The ip http server is enabled.
Any suggestions would be appreciated.
rob.huffman Tue, 12/02/2008 - 09:40
Hi Robert,
Can you please try a cross-over cable. I remember some of the AP's require this.
Hope this helps!
scottmac Tue, 12/02/2008 - 21:13
The AP's IP address goes on the BVI interface, not the Ethernet interface.
Make sure you are plugging into the Ethernet port, not the console port ... both are RJ-45 and side-by-side ... easy to miss one for the other.
Check your software firewall for correct permissions.
Check your speed/duplex settings and/or plug both into a switch.
Plug into the console and see what messages are popping up when you plug the Ethernet cable in.
The crossover cable suggestions are probably your best start.
Good Luck
