12-02-2008 09:54 AM - edited 03-04-2019 12:34 AM
Hi - I noticed something that maybe someone can explain to me if this is unusual or normal. Notice that the IOS version is not the same as the BOOTLDR version even though the router has the boot system command.
Cisco IOS Software, 7200 Software (C7200P-ADVSECURITYK9-M), Version 12.4(15)T3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 25-Jan-08 05:02 by prod_rel_team
ROM: System Bootstrap, Version 12.4(4r)XD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(11)T3, RELEASE SOFTWARE (fc4)
boot-start-marker
boot system flash disk2:c7200p-advsecurityk9-mz.124-15.T3.bin
boot-end-marker
so which IOS version in this router actually running?
Thank you very much for your help!!!
Cheers!
Solved! Go to Solution.
12-02-2008 10:21 AM
The "boot system ... " command is used to tell the router which IOS to boot if you have multiple IOS images. It is not used to tell the router which bootldr to use.
If you want to change the bootldr you need to replace your existing one but if everything is working fine i wouldn't recommend it.
Jon
12-02-2008 12:46 PM
On a 7200, "dir bootflash:" should show you your boot flash contents. You should see the file for your C7200P-KBOOT-M, Version 12.4(11)T3. (Believe this is where crashfiles are normally stored on this device too.)
Ideally, when you upgrade the main IOS you can upgrade the boot IOS to the same version, although as Jon notes, there's often little need to do so.
If you did want to upgrade the boot IOS, you erase or format the bootflash as you would normal flash (NB: format might not be supported on that flash type), and just copy a new boot IOS to that flash.
PS:
Which software is currently running? Your main IOS, although I believe it initially booted using the bootflash IOS which it turn loaded the main IOS.
12-02-2008 10:06 AM
The bootldr image does not have to be the same as the IOS image.
Your router is running IOS 12.4(15)T3 - advanced security feature set.
If you are not experiencing any issues with your router then there is no need to change the bootldr.
Jon
12-02-2008 10:12 AM
Thank you Jon, one last question - how do you change the bootldr? I thought by using the "boot system" command it will change the bootldr the next time the router reboots - is this correct?
Thank you for your assistance.
Cheers!
12-02-2008 10:21 AM
Jon
12-02-2008 12:46 PM
PS:
