BAT (Bulk Admin Tool) & Open office compatibility
Dec 2nd, 2008
Is it possible ? Does it work ? If any of you've had any success running the BAT with OpenOffice, how were you successful ?
Anonymous (not verified) Wed, 12/10/2008 - 14:58
With Portable OpenOffice you do not have to install anything and can edit your BAT csv files on the server. Just download the zip file, extract it, and run Calc directly from the extracted folder. No install necessary. To properly format csv files for CallManager BAT tool, make sure you clear the quotes from the text delimiter when opening the .csv file.
