QoS : MQC , QMP cisco AutoQos
Answered Question
Dec 2nd, 2008
  • Bronze, 100 points or more
what of this metods is the most recommended to implement in a switching and why ?
We will have the 95% of switches Cisco and maybe the 5% 3com, and we will use a ccm 6 and cisco phones. And we will have traffic of video conference.
If there are any form to tune the autoqos to improve the performance of videoconference or i have to use mqc.
Could you refer me some information ?
thanks a lot.
Correct Answer by Marwan ALshawi about 8 years 7 months ago
dependes on the switch models u gopnna have
what i would suggest
if u gonna use 3550/3560 or 2900/ on the access lswitches just enable qos enable priority queue then enable autoqos
and trust DSCP on uplink ports
on distribution switches u can do the same but if u have speciall requirments such as policing and rate limiting u can go with MQC
for video u need to make sure what marking the vediveo endpoint give to its traffic and make sure it has enough bandwith in the port queue and trust all the path
good luck
hope this helps
Correct Answer
Marwan ALshawi Tue, 12/02/2008 - 12:50
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
good luck
hope this helps
arturo.guzman Tue, 12/09/2008 - 08:52
My core is an switch 6500 and the distribution and access layer are 3750, we need QoS for Videoconference and Telephony, could you give me and advice to implement it ?
thanks.
