Sample TAR for passthrough?
Dec 2nd, 2008
WCS 5.1. I can't find any way to download a sample.tar file from the WCS for a passthrough template, only for a webauth (username+password) template. Is it in there and I'm just blind? Or is there anyplace else I can find a tar bundle template for a "check the box" passthrough splash page?
Robert.N.Barrett_2 Fri, 05/15/2009 - 07:32
If you are a windows user, google "tar windows" and get the 1.13 binaries. Once you have it installed and operational, you can modify the following command to take your login.html and image files and make them into a tar file. On my computer, for simplicity, the login.html is in the root of C:, and my images are in the c:\images subdirectory.
c:\progra~1\gnuwin32\bin\tar -cvf test.tar login.html images/logo_bar.jpg images
/new_logo.jpg
George Stefanick Sun, 05/24/2009 - 11:26
As grzwgorz pointed out 7zip works great... i just used it to tar up my new guest page ... works like a charm !
Trending Topics - Security & Network
