CAS behind NAT
Dec 2nd, 2008
I have a a setup with one CAM, one CAS and a firewall between them. There is also NAT in place.
I changed the requiered things like in the configuration guide.
After the changes, I'm able to connect the CAM with the CAS. But after the a reboot of the CAS the connection is broken and cannot be "repaired" because the CAM tries to connect to the original IP and not to the NAT IP which it was connected to earlier. I can only "repair" the connection when I delete the CAS on the CAM an reinitiate the connection
fouzi Wed, 01/21/2009 - 06:56
wkhanagov Thu, 04/09/2009 - 10:55
Fouzi,
Were you able to get this issue resolved? I'm having the same problem with a firewall and NAT between CAM and CAS.
wkhanagov Thu, 04/09/2009 - 11:37
Thanks for your quick response!
I went through and double checked the restartweb and starttomcat files in /perfigo/access/bin. They both contain the -Djava.rmi.servere.host=(my CAS name). I have also verified that the hosts file on the CAM in /etc/ has the public IP and hostname of the CAS. I then restarted the perfigo services on the CAS. So, everything appears to be in place, and when I didn't loose connectivity with the CAS after restarting the perfigo services, but if I reboot the CAS, I will.
wkhanagov Thu, 04/09/2009 - 12:12
Thanks again for your response. It seems the issue has gone away. I'm able to reconnet to the CAS after a reboot!
- William
