Synchronize To/With Peer - CSC-SSM
Dec 2nd, 2008
The CSC-SSM Administrator Guide states that once the failover peer device is detected, one should see 'synchronize with peer' on the primary device window.
But in my case, both primary and secondary are showing the 'sychronize TO peer' button. Is something wrong in that? Other than that both of the devices are synchronized in my scenario.
Lastly, how do I identify which is the primary and secondary device. Nothing different can I see on the GUI on CSC-SSM.
Thanks.
solpandor Wed, 12/03/2008 - 08:23
thats fine. It is the same on my setup as well. the Primay firewall will also be the primary CSC module and if the firewall were to fail then traffic will continue to pass to the secondary firewall.
My understanding on this next bit is slightly unclear but i think If the CSC Module on the primary firewall were to fail, then traffic will be allowed to pass through as normal.
