CME + Locales
Dec 2nd, 2008
Hi There,
I'm trying to configure the Portuguese Locale for 7911G in CME
I tryied to follow the Config Guide.. but I don't know what I'm doing wrong...
I downloaded the locale file, now it is in the flash:/
pt-tc-sccp.jar
I created the alias:
tftp-server flash:/pt-tc-sccp.jar alias user_define_1/tc-sccp.jar
I copy the locale to the user_define_1:
flash:user_define_1/tc_sccp.jar
Now I try this, and receive an error:
Router(config)#telephony-service
Router(config-telephony)#user-locale 1 U1 BR
Updating CNF files
CNF-FILES: Clock is not set or synchronized, retaining old versionStamps
Cannot open flash:/its/user_define_1_tags_file, some TAGs will be displayed in English
Cannot open flash:/its/user_define_1_utf8_tags_file, some TAGs will be displayed in English
CNF files update complete
Please issue 'create cnf' command after the locale change
What is missing ?
Thanks.
Andrei.
Rob Huffman Tue, 12/02/2008 - 15:43
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Andrei,
Can you try adding the command "create cnf-files"
create cnf-files
Hope this helps!
Rob
andrei.goncalves Wed, 12/03/2008 - 07:59
Hi Rob !
I tryied, but the error persist...
The conf. guide talk about those "language_tags_file" and _language_utf8_tags_file" .. but they didn't come with the packgage...
This is a part of running conf.
telephony-service
max-ephones 96
max-dn 288
ip source-address 10.2.41.22 port 2000
timeouts interdigit 3
cnf-file location flash:
user-locale 1 U1 BR
network-locale PT
time-zone 17
time-format 24
max-conferences 16 gain -6
moh music-on-hold.au
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
# show flash
78 70331 Dec 3 2008 15:53:54 +00:00 pt-tc-sccp.jar
114 70331 Dec 3 2008 15:56:56 +00:00 its/tc-sccp.jar
115 70331 Dec 3 2008 15:51:44 +00:00 user_define_1/tc-sccp.jar
(config-telephony)#create cnf-files
Creating CNF files
I can't find the problem.
Thanks.
Andrei.
andrei.goncalves Wed, 12/03/2008 - 08:35
Ok, I found those 2 files...
that's the result
Updating CNF files
Processing file:flash:/its/user_define_1_tags_file
Processing file:flash:/its/user_define_1_utf8_tags_file
CNF file creation is already On
Updating CNF files
But the softkeys are sill in english..
Thanks.
Andrei.
