12-03-2008 12:08 AM - edited 03-04-2019 12:34 AM
I have two Cisco 2811 routers connecting my Head office and Branch office via Metro E link. I have setup and configured ISDN link as backup for this MetroE link. I am testing on the ISDN connectivity. I am getting disconnected with in a second after the connection is established. The debug error says " ISDN_HANGUP received. I didn't configure anything on this (or I may unknowingly configured it). Please help to identify the problem and let me know how can i correct it.
Taj
The configuration and debug is attached
Solved! Go to Solution.
12-08-2008 11:26 PM
Hello Taj,
now that I see the whole configurations I see that you have enabled AAA new model.
I've reviewed some configurations I used in a similar scenario:
I would add the following in global config:
aaa authentication ppp default local
on both routers
Hope to help
Giuseppe
12-03-2008 12:10 AM
12-03-2008 02:55 AM
Hello Mohammed,
I cannot open your attachment it says file not exists
However:
check if there are issues with isdn caller screening
I shouldn't be a ppp authentication issue but also depends from the debug you have enabled
I would suggest
debug isdn q921
debug isdn q931
debug ppp negotation
debug ppp authentication
Make other attempts with all of these debugs active and post the output (sorry if you have already done)
Hope to help
Giuseppe
12-03-2008 08:07 AM
Taj
I am not sure why Guiseppe had problems opening your file, but it opened just fine for me. I have looked at it and believe that there are 2 lines that are especially significant:
Dec 3 07:06:32.890: ISDN Se1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0007
Dec 3 07:06:32.950: ISDN Se1/0:15 EVENT: UserIdle: callid 0x8008 received ISDN_HANGUP (0x1)
this shows that your head office sends CONNECT_ACK which is a sign that things are processing normally on the head office. Then you recieve ISDN_HANGUP which is a sign that the issue is at the branch office since the branch office is the one that initiated the hang up. I believe that to solve the issue that you will need debugs from the branch office. In addition to the debug isdn q931 that you were running it might be helpful to run debug ppp negotiation and debug ppp authentication.
Rick
12-03-2008 09:38 AM
Hello Taj, Rick
it was a problem of my office PC I can open the file.
I see
Dec 3 07:06:32.950: ISDN Se1/0:15 EVENTd: process_disconnect: call id 0x8008, call type is DATA, b_idb 0x44C92608, ces 1, cause Normal call clearing(0x10)
Dec 3 07:06:32.950: ISDN Se1/0:15 EVENTd: calltrkr_call_disconnected: isdn_info=0x44C9A3FC, call_id=0x8008
Dec 3 07:06:32.950: ISDN Se1/0:15 EVENTd: process_disconnect: Raw Release Message
Probably a PPP authentication failure repeat your tests with the debugs I listed in my first post that are the same suggested by Rick
Hope to help
Giuseppe
12-03-2008 07:04 PM
12-04-2008 04:48 AM
could you pls post debug ppp auth?
Nishith
12-04-2008 05:03 AM
Hello Taj,
I've given a look to the last debug outputs.
There is no authentication issue but it is something else that happens on the heade end:
Hdoffice
Dec 4 02:34:47.009: Se1/0:30 PPP: Phase is FORWARDING, Attempting Forward
Dec 4 02:34:47.009: Se1/0:30 PPP: Phase is ESTABLISHING, Finish LCP
Dec 4 02:34:47.009: Se1/0:30 PPP: Phase is VIRTUALIZED
Dec 4 02:34:47.013: Se1/0:30 PPP: Sending Acct Event[Down] id[1E6]
Dec 4 02:34:47.013: Se1/0:30 PPP: Phase is TERMINATING
Dec 4 02:34:47.013: Se1/0:30 LCP: O TERMREQ [Open] id 14 len 4
Dec 4 02:34:47.013: Vi1 PPP: Phase is DOWN, Setup
Dec 4 02:34:47.013: Se1/0:30 IPCP: LCP not open, discarding packet
Dec 4 02:34:47.021: Se1/0:30 LCP: I TERMACK [TERMsent] id 14 len 4
Dec 4 02:34:47.301: ISDN Se1/0:15 Q931: RELEASE_COMP pd = 8 callref = 0x000
and the exchange of messages is:
HD : Dec 4 02:34:47.013: Se1/0:30 LCP: O TERMREQ [Open] id 14 len 4
Branch: Dec 4 02:34:47.030: Se1/0:0 LCP: I TERMREQ [Open] id 14 len 4
Branch: Dec 4 02:34:47.030: Se1/0:0 LCP: O TERMACK [Open] id 14 len 4
HD: Dec 4 02:34:47.021: Se1/0:30 LCP: I TERMACK [TERMsent] id 14 len 4
May you provide a filtered version of head end configuration something doesn't work after the message virtualized
the head end router terminates the call as you can see above and the branch router agrees.
Your configuration can be missing some command to setup VPDN or be in the middle between classic ISDN and VPDN
Hope to help
Giuseppe
12-08-2008 06:41 PM
Hi Giuseppe,
thanks for the information. Please let me know how can I find out the working configuration for my ISDN setup. From the first glance, I dont see any configuration issue, I may be wrong on this. How can i find out that my isdn is VPDN or classic ISDN.
Taj
12-08-2008 07:19 PM
Hi Giuseppe,
I did another test of isdn with the following debug commands.
debug vpdn event
debug ppp multilink events
P.S. - Please note that I have renamed router Hdoffice to KimChuan.
If you notice that there is one error message "Vi1 MLP: Invalid dialer Se1/0:30". I am confused why the isdn is trying to establish connection for interface se1/0:30. Do i need to configure ser1/0:30 in the router.
Dec 9 03:11:22.988: Se1/0:30 PPP: Phase is VIRTUALIZED
Dec 9 03:11:22.988: Se1/0:30 MLP: Adding link to bundle
Dec 9 03:11:22.988: Vi1 MLP: Invalid dialer Se1/0:30
Dec 9 03:11:22.988: Se1/0:30 PPP: Sending Acct Event[Down] id[2A]
Dec 9 03:11:22.988: Se1/0:30 PPP: Phase is TERMINATING
Taj
12-08-2008 08:41 PM
Taj
interface se1/0:30 is a channel on the PRI for the ISDN. I do not believe that you need to configure that channel specifically. In a previous post you gave a very abreviated configuration of the serial interfaces. If there are any other aspects of the serial interface configuration not included in your post it would be good to see them. It might also be helpful if you would post the configuration of the controller of the router for the serial interface.
Rick
12-08-2008 09:32 PM
12-08-2008 11:26 PM
Hello Taj,
on both routers
Hope to help
Giuseppe
12-09-2008 09:09 PM
Hi Giuseppe,
I have added the 'aaa' statement in the configuration. Additional to that I have also added the following commands in the interface. It is working perfectly now.
interface Serial1/0:15
load-interval 30
dialer idle-timeout 600
ppp authentication chap
interface Dialer0
load-interval 30
I did the 'isdn test call' command and the connection worked very well. The isdn connectivity was up until the idle timeout expired. However I want to know is there any way to forcely close the isdn connection. I did a 'shut/no shut' on int ser1/0:15 to force close the isdn connection. Is this the correct way or is there a better way to do this. However this is not a big concern to me now just would like to know.
My Sincere thanks to you and Rick for walking me through this problem.
My next task would be to make configuration changes so that isdn can auto-establish the conection once the main link is down. The challenge I am forseeing is that the main link (MetroE) is residing in another switch. So I need to configure such that the dialer interface can monitor the MetroE link and initiate isdn once the metroE link is down. I know I need to configure routing with higher metric etc etc. Let me try to figure this out, if I encounter any problem, I know where and who to look for.
Once again thanks a lot to Giuseppe and Rick. Your help is much appreciated.
Taj
