service-policy input doesn't work
mats.brynolf
I have a question about port-based QoS on a layer 3 interface.
I can't seem to get this working correctly so any suggestions would be helpful.
We wan't to mark all incoming traffic on our 6504/sup720 (g3/1) and then trust the traffic going through our core. For some reason it dosen't seem to work when we use the service-policy input command on the incoming interface. However, when we apply the service-policy command on the egress interface and user service-policy output it works.
This is how the configuration looks like;
interface GigabitEthernet3/1
ip address x.x.x.x x.x.x.x
ip access-group 135 in
ip pim bsr-border
ip pim sparse-mode
ip multicast boundary 50
wrr-queue bandwidth percent 65 20 15
wrr-queue queue-limit 40 30 10
wrr-queue random-detect min-threshold 1 75 90 95 95 95 95 100 100
wrr-queue random-detect min-threshold 2 80 85 90 95 95 95 95 95
wrr-queue random-detect min-threshold 3 100 100 100 100 100 100 100 100
wrr-queue random-detect max-threshold 1 95 95 98 99 99 99 100 100
wrr-queue random-detect max-threshold 2 95 97 98 99 99 99 100 100
wrr-queue cos-map 1 7 1
wrr-queue cos-map 1 8 4
wrr-queue cos-map 2 2 2
wrr-queue cos-map 3 1 6
wrr-queue cos-map 3 2 7
wrr-queue cos-map 3 8 3
flowcontrol send off
service-policy input iptv-qos-map
policy-map iptv-qos-map
class iptv-class
set dscp 32
class-map match-any iptv-class
match access-group name iptv-acl
ip access-list extended iptv-acl
permit ip any any
IPTV
Cisco 6504
Cisco 6509
Cisco 3560 <- This is where check if we get the right DSCP value from IPTV
15 Replies 15
ariela
Level 4
Level 4
I didn't understand what is your goal. Maybe the command "mls qos map cos-dscp" does the trick. Please check before that link, could be helpful:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper0900aecd803e5269.html
Let me know
Andrea
Question: the 'mls qos' is enabled?
Andrea
ps: another good link is:
http://www.gossamer-threads.com/lists/cisco/nsp/80620
As you can see, you have some options, one of them is simplify your policy with something like that:
policy-map set-dscp-32
class class-default
set dscp 32
Another good idea is to move the trusted boundary, mark on access-layer (Cos 4 or DSCP 32) and then on your 6500 trust that value.
Thanks Andrea for the great links.
Our goal is to rewrite all incoming traffic on gig3/1 to dscp 32
Yes mls qos is enabled globally
I don't see how this is more simplyfied than what we have now?
class class-default
set dscp 32
I've also tried to set mls qos trust on gig3/1 and it still won't rewrite to 32.
I need more details about your IPTV infrastructure. Have you got the multicast source directly connected to gig3/1, or to another access layer?
Please let me know
Andrea
ps: in my opinion, in terms of commands and syntax, using the class-default to mark all traffic IP is more simplyfied that creating a specific class, and a generic access list. Simple is better, isn't it? ;)
The multicast source addresses are several route hops away connected on gig3/1.
I don't think its just a problem with multicast. I tested on another gig3/2 layer3 interface where Internet traffic flows and I can't rewrite the traffic there either. I also tried on a vlan interface mls qos vlan-based and with service-policy input and it works ok.
We are running on module type WS-X6724-SFP.
I'm also adding the global configuration we are using:
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos map ip-prec-dscp 0 8 16 24 32 46 48 56
mls qos
I was talking about topology, and not strictly for multicast.
The first idea is: you could mark with CoS 4 or DSCP 32 in an upstream switch or router, then trust that value on gig3/1
Unfortunately this is not possible because those routers are not managed by us.
This is how the mls qos vlan-based configuration looks like
interface Vlan607
ip access-group 103 in
no ip redirects
no ip proxy-arp
service-policy input internet-qos-map
end
interface GigabitEthernet3/22
switchport
switchport trunk allowed vlan 607
switchport mode trunk
no ip address
wrr-queue random-detect min-threshold 3 99 99 99 99 99 99 99 100
mls qos vlan-based
end
class-map match-all internet-class
match access-group name internet-acl
policy-map internet-qos-map
class internet-class
set dscp 8
ip access-list extended internet-acl
permit ip any any
But gig3/1 is a trunk?
gig3/1 is not a trunk interface. gig3/22 is a trunk interface and its on this interface we got the rewriting to work.
for a non trunk interfaces a good idea is to use the 'mls qos cos' command, to set a default cos for all traffic in ingress on this specific interface. CoS 4 will be DSCP 32.
Have you already tryed that way?
Andrea
edit: use the keyword 'override', as
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_m2.html#wp1011989
I have not tried that yet. I won't be able to test this until next week. Thanks Andrea for the tip.
'mls qos cos 4' did the trick for this case, but I also have another interface on the same switch where I need to seperate different types of traffic ie. Internet, VoIP etc. into seperate queues. The only way I can do that is by using MQC.
So 'mls qos cos' won't help me in that case.
I discovered the reason why the IPTV/UDP packets did not get marked. The reason seem to be that you can't change the existing multicast stream with MQC. The only way to see the change was to shutdown the interface (g3/1) and bring it up again. Then we could see the right DSCP value 32. Stopping and starting the multicast stream from its source did not help.
So there is nothing wrong with my initial configuration
