Unity transfer calling
Dec 3rd, 2008
Hi :
Our company has 50 licenses of Unity server, but in fact we have more than 50 extension number , so there has some extension has no voice message box, and if someone call the auto telephonist (it is a call handler in Unity), when you dial the extension number, if the extension has voice mailbox, no problem, but if it has no mailbox, the Unity doesn't forward your calling , prompt you "invalid entry" , who can tell me what how I do about it using existing license ? thanks!
Rob Huffman Wed, 12/03/2008 - 06:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Liu,
There are a couple of ways to do this. Have a look at the following on how to set up the Call Handler (lock a key to the Caller System Transfer) in Unity to allow callers to Transfer to non-subscribers;
Setting Up System Transfers
In your organization, you may find that callers want to be able to dial numbers that are not typically listed in directory assistance. For example, subscribers and outsider callers may find it convenient to be able to call Cisco Unity and transfer from the Opening Greeting or another call handler to a lobby extension, conference room extension, or an extension assigned to someone in the organization who is not a Cisco Unity subscriber, such as an employee who is visiting from another site and is using a guest office.
You can route callers to one of two "system transfer" conversations, both of which offer callers the ability to transfer to numbers that are not associated with Cisco Unity subscribers:
You can route callers to either system transfer conversation in several ways, including: Caller System Transfer, This conversation prompts callers to enter the number that they want to transfer to.
By offering a system transfer as a "one-key dialing" option. You can specify either system transfer (on the Caller Input page for any call handler or subscriber greeting) as the action that Cisco Unity performs when a caller presses a particular key during the greeting.
For example, to allow all callers to transfer to a lobby phone, guest office, or a conference room from the Opening Greeting, you could specify that Cisco Unity will offer Caller System Transfers when callers press 3.
Call Management > Call Handlers > Caller Input Page
Action Indicate the action that Cisco Unity performs after a caller presses the corresponding key.
Send Caller To - Cisco Unity sends the call to the destination that you select:
Caller System Transfer - Sends the call to a conversation that allows callers to transfer to a number that they specify. For example, callers may want to dial a lobby or conference room phone that is not associated with a Cisco Unity subscriber. Cisco Unity performs the transfer only when the CS_Default_System_Transfer restriction table permits it.
You could also set up these special clients as Internet Subscribers, which does not require a User License but does allow them to be listed in the directory and to be able to be dialed from the Call Handler:)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/404/networking/guide/dom/netd300.html
Hope this helps!
Rob
3dtgnt_ljm Wed, 12/03/2008 - 22:45
Hi Rob :
Thanks for your reply and I am trying by your suggestion, but when I dial the special number , it said: you cannot be transfered to the number, check..
I think I need change the setting of "CS_Default_System_transfer" , but where is it ? Can you tell me ? thank you .
