outbound calls with call redirect round robin
Dec 3rd, 2008
  • Bronze, 100 points or more
Is it possible with IPCC5X to configure script to send calls to remote destinations in round robin fashion i.e. we do have two different telcom providers and send some calls over one provider than the others. Is it achievable in IPCC5X.
Cheers
Ikram
Jonathan Schulenberg Wed, 12/03/2008 - 07:57
  • Cisco Designated VIP,
    2017 IP Telephony
Not within UCCX; however, you can use a route group on the CTI Ports and Agent ACD lines that uses Circular as the Distribution Algorithm and then insert the gateway/trunks of the two different carriers.
mikram Thu, 12/04/2008 - 02:16
Thanks, but I managed to find solution just pointing to phone number and then route to PSTN through different route group.
C
mikram Thu, 12/04/2008 - 02:33
Jonathan,
Never heard of using CTI ports as part of Route group. Route groups can only contain gateways and its analog or Digital ports. Have you done this thing in real environment or just a thought?
Jonathan Schulenberg Wed, 12/10/2008 - 18:31
    2017 IP Telephony
I was referring to assigning route patterns to a partition of the CTI Ports' CSS which contains a route list and route group that selects from multiple gateways.
