12-03-2008 02:46 AM - edited 03-06-2019 02:46 AM
Hi Folks,
I'm getting the error message below on the 6509 :
SNMP-3-INPUT_QFULL_ERR: Packet dropped due to input
queue full
12-03-2008 02:56 AM
%SNMP-3-INPUT_QFULL_ERR : Packet dropped due to input queue full
Explanation Snmp packet dropped due to input queue full error.
Recommended Action Use the command show snmp to see the number of packets dropped. Stop any SNMP access to the device until the error condition is recovered.
Investigate if it could be a possible bug of your specific IOS (please let me know the IOS release).
Andrea
12-03-2008 03:54 AM
The IOS is s3223-advipservicesk9_wan-mz.122-33.SXH.bin
See sho snmp below,
IT-swi-ios-acc-vop-02-wu#sh snmp
Chassis: SMG1123N54F
86912610 SNMP packets input
0 Bad SNMP version errors
349699 Unknown community name
0 Illegal operation for community name supplied
0 Encoding errors
378869572 Number of requested variables
786 Number of altered variables
67956787 Get-request PDUs
18346242 Get-next PDUs
166 Set-request PDUs
150921 Input queue packet drops (Maximum queue size 1000)
86411014 SNMP packets output
0 Too big errors (Maximum packet size 1500)
389033 No such name errors
0 Bad values errors
0 General errors
86411012 Response PDUs
2 Trap PDUs
SNMP logging: disabled
I have stopped all the snmp access.
Rgds,
Keith
12-03-2008 05:18 AM
And after the stop the error condition is recovered?
Andrea
12-03-2008 05:34 AM
You have an IOS bug: CSCsk27147
You need to upgrade it.
Best Regards
Andrea
12-03-2008 05:36 AM
I forgot more details :)
CSCsk27147 Bug Details
SNMP stops responding while polling from CISCO-MEMORYPOOL-MIB
Symptoms: The following SNMP is incorrectly generated:
"%SNMP-3-INPUT_QFULL_ERR: Packet dropped due to input queue full
This issue is affecting the CISCO-MEMORYPOOL-MIB instead.
Conditions: Occurs on a Cisco 2600 series router running Cisco IOS Release 12.4(11)T3. The router
keeps dropping SNMP packets. The log shows that the packets are dropped because of the input queue
beeing full. Although the utilization is sometimes high, this could not be the root cause, as the router
keeps dropping packets regardles of the current utilization. Also, the snmp process takes 5-20% of the
CPU load.
Workaround: Exclude ciscoMemoryPoolMIB from your query with the following commands:
snmp-server view public-view iso included
snmp-server view public-view ciscoMemoryPoolMIB excluded
Apply this view to the RW community string. This view will exclude only ciscoMemoryPoolMib, all other
MIBs will be available.
My advice: upgrade to 12.2(33)SXH4, the last release of your train.
Andrea
12-03-2008 06:23 AM
Andrea,
I'm still getting the error messages even after excluding the ciscoMemomoryPoolMib, see commands below,
snmp-server community ********** RO
snmp-server community ********** view public-view RW
The other thing:
The SNMP Engine using about 30% of cpu.
I will upgrade to latest ios.
Thanks a lot Andrea, much appreciated.
Rgds,
Keith
12-03-2008 06:33 AM
You're welcome, Keith,
please let me know if I could be more helpful.
Andrea
01-02-2009 07:49 AM
Andrea,
Upgraded to IOS 12.2(33)SXH4... Problem resolved.
Thanks a lot for your help.
Rgds,
Keith
