7931 Ringtone
Answered Question
Dec 3rd, 2008
How do assign a different ringtone to my 7931? I can browse and assign using a 7941.. but obviously the 7931's are different..
Correct Answer by rob.huffman about 7 years 10 months ago
Hi Huw,
Good stuff my friend! I believe that button 24 should be the Menu access by default. Can you have a look here;
Hope this helps!
Overall Rating: 4.5 (2 ratings)
rob.huffman Wed, 12/03/2008 - 05:35
Hi Huw,
Nice to talk with you again!
Select the Ring Type
To change the ring type, use the following method:
1. Press line button 24 to access the Applications Menu key (default). If you are not sure of which button is configured as the Applications Menu key, use the Navigation button to display all button configurations.
2. Use the Navigation pad to choose Settings, or press keypad digit 3.
3. Press 2 for Ring Type, or use the Navigation pad to access Ring Type and press the Select button.
4. Use the Navigation pad to scroll through the list of ring types. Press the Play soft key to hear samples.
5. Highlight the ring you want, and then press the Select button.
6. Press the Save soft key to save the setting, or press Cancel to exit to the previous menu without changing the setting.
7. Press the Exit soft key to return to the main directory menu.
Hope this helps!
davieshuw Wed, 12/03/2008 - 06:47
Hi Bob,
You're in danger of making it onto my Christmas card list!
Cheers for that. I've taken a look and my line button 24 doesn't do much. I've tried my navigation pad but don't get anywhere either. Is there any command (via the command line or GUI) i need to enter to make button 24 acces the apps menu?
davieshuw Wed, 12/03/2008 - 07:17
spot on. I created an ephone template and added the button layout set command. Works a treat.
