How to move L3 switch from 1 place to another place without affecting N/w?
Dec 3rd, 2008
I have connected L3 switch 30 L2 switches. Due to power reason i want to move L3 switch from one place to another place without affecting the N/w. How can i do this..
John Blakley Wed, 12/03/2008 - 06:40
Are you needing to move cat5 or just power? If you have dual power supplies, you should be able to unplug one and connect it to the new location, and then disconnect the other and do the same. If you don't have redundant power supplies, you'll have to schedule for after hours. :-)
HTH,
John
