12-03-2008 07:59 AM - edited 03-06-2019 02:47 AM
What is the Command to disable Dynamic Trunking Protocol on a Catalyst 4006 Switch? I thought it was #switchport mode access, But It will not accept the word Switch as part of a command. Any Ideas??
Solved! Go to Solution.
12-03-2008 08:08 AM
James
Are you runnning IOS or CatOS. If IOS then are you using this command in interface configuration mode ie.
4500(config)# int gi4/1
4500(config-if)# switchport mode access
Jon
12-03-2008 08:08 AM
James
Jon
12-03-2008 08:35 AM
Jon,
Thanks alot, that was right on the Money. The Tech I was working with did not go into the interface before entering the command.
