CFB SCCP not operational
Dec 3rd, 2008
Hi There,
I'm trying to configure a Gateway dsp for conference on CCM 6.1 (SCCP) but SCCP state is not operational.
following conf and trace:
I did this config:
RO-FR-VIL-CIM-2821-1#sh running-config |
voice-card 0
dspfarm
dsp services dspfarm
sccp local GigabitEthernet0/1
sccp ccm 10.214.6.10 identifier 1 version 6.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1
associate ccm 1 priority 1
associate profile 1 register conf-vill
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
maximum sessions 8
associate application SCCP
and show sccp
RO-FR-VIL-CIM-2821-1#show sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/1
IPv4 Address: 10.241.13.1
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.214.6.10, Port Number: 2000
Priority: N/A, Version: 6.0, Identifier: 1
Trustpoint: N/A
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: CONNECT_PENDING, Profile Identifier: 1
Reported Max Streams: 64, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
debug sccp:
000259: Dec 2 20:29:25.578 WET: sccp_oper_state_bring_up: Not able to create MP Auto-Config process
000260: Dec 2 20:29:25.586 WET: sym_xapp_xlate_rpm_codec: payload 5
000261: Dec 2 20:29:25.586 WET: sym_xapp_xlate_rpm_codec: payload 6
000262: Dec 2 20:29:25.586 WET: sym_xapp_xlate_rpm_codec: payload 5
000263: Dec 2 20:29:25.586 WET: sym_xapp_xlate_rpm_codec: payload 6
000264: Dec 2 20:29:25.586 WET: sym_xapp_process_ccapi_events: minor is ZERO - should be non-zero for CCAPI event
000265: Dec 2 20:29:25.586 WET: sym_xapp_xlate_ccapi_eve: Unsupported ccapi eve 2
000266: Dec 2 20:29:25.586 WET: sym_xapp_process_ccapi_events: Unsupported ccapi eve_id 2
thanks for your help.
jbarcena Wed, 12/03/2008 - 09:23
Verify that you are using the exact same name in CCM: conf-vill it is case sensitive. Then try a no sccp and then sccp.
Also how are you adding the HCB in CCM? as enhanced IOS or plain IOS?
fernandezj Thu, 12/04/2008 - 04:37
hi,
the name is ok. HCB type is "enhanced IOS".
strange..
Best reagrds
Giuseppe Larosa Thu, 12/04/2008 - 05:22
Hello Jerome,
you should verify that the device can access the call manager on TCP port 2000: there is any router or firewall on the path ?
this is from one conference bridge in our network
V-RMSXR00-CB01#show sccp
Gateway IP Address: 10.80.128.54, Port Number: 2000
IP Precedence: 5
Call Manager: 10.28.144.12, Port Number: 2000
Priority: N/A, Version: 5.0.1, Identifier: 1
Call Manager: 10.24.144.14, Port Number: 2000
Priority: N/A, Version: 5.0.1, Identifier: 2
Conferencing Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 10.28.144.12, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
it is registered :
Conference Bridge InformationConference Bridge : V-RMSXR00-CB01 (V-RMSXR00-CB01)
Registration Registered with Cisco Unified Communications Manager 10.28.144.12
Hope to help
Giuseppe
fernandezj Thu, 12/04/2008 - 05:38
hello Giuseppe,
the router can join CCM on port tcp 2000 and there is no firewall between Router and CCM.
I think the problem comes from the router (but I'm not sure) see "debug sccp" but I can not interpret :-(
Best regards.
iptuser55 Thu, 12/04/2008 - 05:59
Is it not the version number being 6.0 maybe change it to 4.0 - I think I remember a similar post????
Giuseppe Larosa Thu, 12/04/2008 - 06:05
actually my CUCM are 6.1.2 but on the device I have
sccp ccm 10.28.144.12 identifier 1 version 5.0.1
Hope to help
Giuseppe
fernandezj Thu, 12/04/2008 - 06:30
actualy CUCM are 6.1.1
i test the following parameters:
- sccp ccm 10.214.6.10 identifier 1 version 6.0
- sccp ccm 10.214.6.10 identifier 1 version 5.0.1
- #sccp ccm 10.214.6.10 identifier 1 version 4.1
and the result is same...
see debug sccp error:
000404: Dec 4 15:23:50.856 WET: sccp_oper_state_bring_up: Not able to create MP Auto-Config proces
000405: Dec 4 15:23:50.860 WET: sym_xapp_xlate_rpm_codec: payload 5
000406: Dec 4 15:23:50.860 WET: sym_xapp_xlate_rpm_codec: payload 6
000407: Dec 4 15:23:50.860 WET: sym_xapp_xlate_rpm_codec: payload 5
000408: Dec 4 15:23:50.860 WET: sym_xapp_xlate_rpm_codec: payload 6
000409: Dec 4 15:23:50.864 WET: sym_xapp_process_ccapi_events: minor is ZERO - should be non-zero
000410: Dec 4 15:23:50.864 WET: sym_xapp_xlate_ccapi_eve: Unsupported ccapi eve 2
000411: Dec 4 15:23:50.864 WET: sym_xapp_process_ccapi_events: Unsupported ccapi eve_id 2
fernandezj Thu, 12/04/2008 - 06:25
hi,
strange..
Best reagrds
jbarcena Thu, 12/04/2008 - 07:38
Try changing it to only IOS, do not use enhanced, I ran into a bug a while ago with CCM 6 and HCB, it did not registered while using enhanced IOS Conference Bridge, I had to changed it.
//J
fernandezj Mon, 12/08/2008 - 02:57
I'm verify with 2 configuration (enhanced IOS and IOS) same result..:-(
I check if this problem is Hardware.
best regards
