What does 'not a gateway' mean?
Answered Question
Dec 3rd, 2008
Hi All,
Today I issued "show ip traffic" on the 2960 Catalyst switch, and found '4554734 not a gateway' in Rcvd section. Somebody here can tell me what 'not a gateway' mean? Is that normal?
Much appreciated.
Correct Answer by Harold Ritter about 8 years 3 months ago
Robert,
My guess is that you have configured an IP address on the 2960 for management purposes only (it is not configured as a router) but some other device on that subnet is trying to use it as it default gateway.
Overall Rating: 4.3 (3 ratings)
John Blakley Wed, 12/03/2008 - 08:27
  • Purple, 4500 points or more
It's normal. It means that the packet isn't routed out a gateway and stays on the local segment.
HTH,
John
*please rate if helpful*
Harold Ritter Wed, 12/03/2008 - 10:25
  • Cisco Employee,
John,
This counter is incremented when the device is not configured as an ip router (no ip routing) and you receive an ip packet for a destination that is not your local IP address.
Correct Answer
Harold Ritter Wed, 12/03/2008 - 13:29
  • Cisco Employee,
Robert,
