BARS Backup
CM 4.2.3
Can someone tell me the best way to verify if bars is backing up successfully or if it returned errors?
I am used to going into the bars log file and making sure I see
[10:07:19 PM] BARS Scheduler backup operation returned: Success
[11:00:00 PM] BARS Scheduler hourly tracing, current system time = 11:00:00 PM"
But I have another CM Cluster 4.2.3 that does not show these lines at the end of the log file. Thoughts?
irisrios Wed, 12/10/2008 - 14:51
  • Silver, 250 points or more
To verify if backup is successful perform the following steps:
Open Restore Wizard from BARS menu, Restore>Restore Wizard.
Select Tape in Step 1.
Go to Step 2 by clicking on Next.
If Step 2 displays the server and the application the backup was successful.
This procedure makes no changes to the system so can be safely used to test the validity of the backup.
