CDR
dvanzee
Level 2
Level 2
Can someone tell me the best way to verify I have the correct CDR configuration or if it's activated? CM 4.2.3
Adrian Saavedra
Level 7
Level 7
Hi friend,
CDR is not enabled by default in CM. Please check this URL about Cisco CallManager Configuration.
http://www.cisco.com/univercd/cc/td/doc/product/voice/vpdd/cdd/4_2/4_2_3/cdr423.pdf
Hope this helps.
Best regards,
- Adrián.
Adrian Saavedra
Level 7
Level 7
Hi friend,
Also you can check the section CDR Analysis and Reporting (about configuring CDR Service Parameters and other stuff) from this URL:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/4_2_3/ccmsrva/sacar1.html
- Adrián.
configure it as explained here:
Cause 2
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008056bd4e.shtml#cause2
java
if this helps, please rate
java
