Route missing
Dec 3rd, 2008
Hi ALL:
It sounds crazy but its happening,while configuring the RP for 6500 i have put some static route , but i dont see them in the routing table,this is new switch and not connected to network , any idea why ?
interface Vlan62
ip address x.x.62.1 255.255.255.0
no ip redirects
arp timeout 60
standby 62 ip x.x.62.254
standby 62 priority 120
standby 62 preempt delay minimum 2
interface Vlan67
ip address x.x.67.1 255.255.255.0
no ip redirects
arp timeout 60
standby 64 ip x.x.64.254
standby 64 priority 120
ip classless
ip route 0.0.0.0 0.0.0.0 Vlan62
ip route x.x.x.0 255.255.255.240 x.x.64.25
ip route 172.20.0.0 255.255.0.0 x.x.64.25
ip route 172.22.0.0 255.255.0.0 x.x.64.25
i
no ip http server
end
Router#show ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
X.0.0.0/24 is subnetted, 2 subnets
C x.x.67.0 is directly connected, Vlan67
C x.x.62.0 is directly connected, Vlan62
S* 0.0.0.0/0 is directly connected, Vlan62
Chao
Vishwa
Overall Rating: 4 (1 ratings)
ajagadee Wed, 12/03/2008 - 09:32
  • Cisco Employee,
Vishwa,
I see couple of things in your configuration and I hope that will clear your route missing issue.
1. SVI VLAN 67
interface Vlan67
no ip redirects
arp timeout 60
You have configured an address of x.x.67.1/24 on the SVI VLAN 67 but the HSRP Standby address is x.x.64.254/24. The third octet is not the same.
2. Also, your static routes that are not showing up in the routing table, that is
are all pointing to a 64.25 address. Is this the correct configuration or did you mean to configure a SVI VLAN 64 and put the x.x.64.x addresses in there.
Arul
*Pls rate if it helps*
Richard Burts Wed, 12/03/2008 - 09:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Vishwa
There is a simple explanation for this. You have configured static routes with this next hop address: x.x.64.25 but there is not anything in the routing table that tells where x.x.64.25 is (and not anything that tells through which interface to go to get to that address). If the next hop address for a static route is not reachable then the static route is not put into the routing table.
Rick
vishwancc Wed, 12/03/2008 - 09:48
Hi Rick,
I see what you are saying.
This switch have a default router to my router interface which have route to x.x.64.25,so i think unit i connect it to the network static route will not come.
Thanks again its people like you who make life simple:-)
Chao
Vishwa
