ACE Question
Dec 3rd, 2008
Hi Experts!
Would really appreciate any suggestions around the best approach to setup the following environment.
13 environments exists with each having 4 servers e.g.
1A, 1B, 1C & 1D
2A, 2B, 2C & 2D
3A, 3B, 3C & 3D
13A, 13B, 13C & 13D
Each individual server in all env. host 8 services TCP 20080-20087
My Goals is to setup different VIP's with each environment and also to keep configuration listing as MINIMAL as possible.
Key requirement: single or multiple Service failure on any server should not take out the entire server from service.
Working through this I realized this would generate 13 x 8 Serverfarms & VIP's also probe traffic will be 13 x 4 x 8 every probe window!!
There must be a better way! Please help!!
litrenta Wed, 12/03/2008 - 13:48
If you are not doing port redirection (in other words you have vip listening on ports TCP 20080-20087 then you only need 13 serverfarms since traffic will be sent to the rserver on the port it came in on. You would however need 8 probes per if you want to check the health of each.
nyr.hakeem-habeeb Thu, 12/04/2008 - 03:11
Hi litrenta
Thank you for your response!
Sorry I didnt mention earlier but another key requirement is for a service failure e.g. port 20080 or 20087 should not take the entire server out of rotation i.e. it should be able to still serve for 20081-20086.
Is this still achievable using 13 serverfarms? If so, please eloborate.
Thanks.
ropethic Thu, 12/04/2008 - 05:54
Configuration is going to depend on whether you want to load balance across ports or the servers.
I am guessing you need to create 13 VIPs based on servers being on different vlans. rservers can be in multiple serverfarms as well.
If you are load balancing across rservers only, then you will need 13 serverfarms with 4 rservers each.
if you are going to load balance across ports then you will still only need 13 server farms with 4 rserver and 8 rserver ports.
Example 1 - just server LB
serverfarm 1a-d
- rserver 1a
-ins
- rserver 1b
Exmaple 2 - port load balance
serverfarm muliport A
-rserver 1a 20080
ins
- rsever 1a 20081
ins
rserv 1a 20082
ins
rserver 1b 20080
ins
so you will need 32 rservers in the server farm
Not sure there is an easier way. Unless there is a common url on the ports that can be loadbalanced using class maps.
