startup running reports differences- out of sync LMS.26
eliaspaulos
I have few devices startup running reports differences in configures with CRYPTO- I did exclude The "certificate" and "ntp clock-period" on RME for those devices but still out of sync for the same crupto issue, I did same thing for many devicess but it's work but not on those few devices. is that device problem or LMS?any body had the same issue before?
Joe Clarke
This is a known issue. Assuming the devices support "show running brief" you can adjust the config fetch transport protocol order to SSH or TELNET is listed before TFTP. The "show running brief" output omits the crypto cert, resulting in a startup and running config which are in sync.
Joe Clarke
