Layer -3 switching
Dec 3rd, 2008
In my company. We have a 4503 series switch. Tow vlan defined in this switch. Vlan 10.10.16.2 255.255.255.128 and other Vlan 2 10.10.16.130 255.255.255.128 and default gateway is 10.10.16.1. Default gateway is of router. and i have a one link of isp Its ip is 202.131.123.218/219/220 subnet mask is 255.255.255.248 and default gateway is 202.131.123.217 and dns of isp is 202.131.104.2 and 202.131.104.3 So please suggest me I want to terminate this link in switch.
Giuseppe Larosa Wed, 12/03/2008 - 11:40
  • Hall of Fame,
    Founding Member
Hello Pradip,
just create a third vlan
config
vlan 3
name ISP
put one or more ports in this vlan
then if you want to use the switch to route between internal lans and ISP VLan
you need to create an SVI
interface vlan3
ip address one of ISP subnet
! no shut
no shut
notice if instead you need to use the ports as L2 switch you can do it there is no problem in this:
you can use the L3 features in some vlans and not in other ones this is left to your choice
Note:
It would be wise to hide the public addresses
I would suggest you to edit your post
mask with x.y. the first two bytes this forum can be read by everyone
Hope to help
Giuseppe
