Load IOS code on redundant SUP
Dec 3rd, 2008
I have a 6509 at a remote site with dual SUP32's running IOS code 12.2(18)SXF4; I would like to upgrade the code. In order to power cycle the switch, I need to have the new code on both the primary and the redundant sup. Loading the new code on the primary sup is easy.
My question is, how could I load the new code on the redundant sup?
Jeremy
anjery1234 Wed, 12/03/2008 - 11:25
copy bootflash://sup-remote didn't help.
Is that a way to copy a code from a primary sup to a standby sup?
carloskuontay Wed, 12/03/2008 - 10:43
Hi Jeremy, in my case I have the IOS in the sup-bootflash. The primary card is in slot 5, and secondary in slot 6. You can execute the following steps:
(Primary Card)
SW#show sup-bootflash:
-#- --length-- -----date/time------ path
1 74637284 Aug 12 2008 14:08:24 s72033-ipservicesk9_wan-mz.122-33.SXH3.bin
2 33554432 Aug 12 2008 16:47:54 sea_log.dat
3 1374 Nov 22 2008 18:37:10 diaginfo_mod2_20081122-183709
(Secondary Card)
SW#show slavesup-bootflash:
1 74573284 Aug 06 2008 12:38:12 s72033-ipservicesk9_wan-mz.122-33.SXH2a.bin
2 33554432 Aug 06 2008 12:43:40 sea_log.dat
To copy from Primary Card to Secondary
copy sup-bootflash:s72033-ipservicesk9_wan-mz.122-33.SXH3.bin slavesup-bootflash
To copy from Secondary Card to Primary
copy slavesup-bootflash:s72033-ipservicesk9_wan-mz.122-33.SXH2a.bin sup-bootflash
anjery1234 Wed, 12/03/2008 - 11:16
Carlos,
Thanks for your help. Couple of questions for you.
1- Did you have to enable versioning?
2- After loading the new code on both sup's, how did you proceed? I guess setting the boot statement.
boot system flash sup-bootdisk:s3223-ipservicesk9_wan-mz.122-18.SXF4.bin
What after that?
Jeremy
Mark Yeates Wed, 12/03/2008 - 11:34
  • Gold, 750 points or more
Jeremy,
After copying the IOS and updating your boot strings you would then reboot the switch. You could also reboot the supervisors individually.
HTH,
Mark
