can any one explain
Answered Question
Dec 3rd, 2008
what is the difference b/w manual down , manual up
GigabitEthernet1/44 unassigned YES unset down down
GigabitEthernet1/45 x.x.x.x YES manual up up
GigabitEthernet1/46 x.x.x.x YES manual up up
GigabitEthernet1/47 x.x.x.x YES manual down down
Correct Answer by Giuseppe Larosa about 8 years 6 months ago
Hello Ocporbust,
here manual refers to the fact that the ip address was configured manually and not using the initial setup process:
think of manual as a property of the IP address
up / down refer to the state of the interface
you can see this:
g1/44 has no ip address unassigned and it is unset
gi1/47 has an ip address that has been manually configured and it is currently down down (not connected I guess)
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Wed, 12/03/2008 - 11:01
  • Hall of Fame,
    Founding Member
Hello Ocporbust,
you can see this:
Hope to help
Giuseppe
