Messages button problem
Dec 3rd, 2008
I have 1 user, when he presses the messages button, Unity is receiving CLID for his 2nd line and not the 1st.
I looked at the call viewer to confirm.
How can i configure it for the 1st line, hos personal extension? In the mean time, I am going to remove the 2nd line and re-add it.
Randall
Rob Huffman Thu, 12/04/2008 - 07:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Randall,
A couple of things to look at here. Is there a message on Line 2 when this happens? If so you may have this setting (set to false)
"Always Use Prime Line for Voice Message". This feature will select Line 2 or others if there is an actual Voicemail Message waiting (with flashing VM Icon) on the secondary lines.
Services > Clusterwide Parameters (Device - Phone)
Always Use Prime Line for Voice Message - True/False
Maybe a routing rule in Unity?
Hope this helps!
Rob
