LMS config changes
We're running LMS 2.6...I have a need to go into all of our routers and switches and modify (or I guess enforce) certain configs...for exapmle, I need to have these lines in all our devices:
tacacs-server host 10.10.10.1
tacacs-server hsot 10.10.10.2
snmp-server community xxx RO
snmp-server host 10.10.10.3 xxx
is there anwyay to go through all the devices, and if those lines don't exist then have LMS deploy those lines?
Joe Clarke Wed, 12/03/2008 - 13:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Absolutely. This is what the baseline compliance feature of RME is all about. You can define a template which contains those commands that are required to be on all devices, and those which should never be found. Then you can check your devices for compliance, and deploy the missing config. Baseline compliance can be found under RME > Config Mgmt > Archive Mgmt > Baseline Templates. Consult the online help for more information.
