CSS 11501 Not Passing HTTPS or 443
jdmonroe
When I go directly to the server address I can resolve both 80 and 443.
When I go via vip I get port 80 but can't connect to port 443.
Simple pass-thru config not terminating the Cert on the CSS or using the SCM.
!*************************** GLOBAL ***************************
ip redundancy
bridge spanning-tree disabled
no restrict web-mgmt
idle timeout web-mgmt 15
app
app session 1.1.1.2 14 authChallenge cisco encryptMd5hash rcmdEnable
dns primary xxx.xxx.13.41
dns secondary xxx.xxx.15.248
ip route 0.0.0.0 0.0.0.0 10.1.104.253 1
-INTERFACE-
interface e1
bridge vlan 10
phy 100Mbits-FD
description "Client-Side VLAN"
interface e4
bridge vlan 20
description "Redundancy Protocol Heartbeat"
phy 100Mbits-FD
interface e8
phy 100Mbits-FD
bridge vlan 30
description "Server-Side VLAN"
interface Ethernet-Mgmt
description "Management"
phy 10Mbits-HD
- CIRCUIT -
circuit VLAN10
redundancy
ip address 10.1.104.3 255.255.255.0
circuit VLAN20
ip address 1.1.1.1 255.255.255.252
redundancy-protocol
circuit VLAN30
redundancy
ip address xxx.xxx.14.52 255.255.255.0
no redirects
- SERVICE -
service Mmobile01
ip address xxx.xxx.14.192
port 80
keepalive type tcp
active
service Mmobile01-443
port 443
keepalive type tcp
active
service Mmobile02
ip address xxx.xxx.14.101
port 80
keepalive type tcp
active
service Mmobile02-443
port 443
keepalive type tcp
active
service Mmobile03
ip address xxx.xxx.14.143
port 80
keepalive type tcp
active
service Mmobile03-443
port 443
keepalive type tcp
active
service Mmobile04
ip address xxx.xxx.14.208
port 80
keepalive type tcp
service Mmobile04-443
port 443
keepalive type tcp
keepalive port 443
service Mmobile05
ip address xxx.xxx.14.169
port 80
keepalive type tcp
active
service Mmobile05-443
port 443
keepalive type tcp
keepalive port 443
active
service UpStreamRouter
ip address 10.1.104.253
type redundancy-up
active
- OWNER -
owner XXXX
content Web-NonProd
vip address xxx.xxx.14.46
add service Mmobile04
add service Mmobile05
balance leastconn
advanced-balance sticky-srcip
protocol tcp
port 80
url "/*"
active
content Web-NonProd-443
balance leastconn
protocol tcp
port 443
add service Mmobile04-443
add service Mmobile05-443
content Web-Prod
vip address xxx.xxx.14.39
add service Mmobile01
add service Mmobile02
add service Mmobile03
balance leastconn
protocol tcp
port 80
url "/*"
active
content Web-Prod-443
balance leastconn
protocol tcp
port 443
url "/*"
add service Mmobile01-443
add service Mmobile02-443
add service Mmobile03-443
active
- GROUP -
group XXXX-NonProd
add destination service Mmobile04
add destination service Mmobile04-443
add destination service Mmobile05-443
active
group XXXX-Prod
add destination service Mmobile01
add destination service Mmobile01-443
add destination service Mmobile02
add destination service Mmobile02-443
add destination service Mmobile03
add destination service Mmobile03-443
sachinga.hcl
Level 4
Level 4
HI,
During the session of the client, the transition is made to SSL port 443 when the client selects a link on the page that redirects to https. This causes a new content rule to be hit and the client may be load-balanced to another server. As the traffic is now encrypted https (SSL/TLS), the CSS is not able to check above layer 4 (the TCP port number) for cookies, URLs etc., because the requests are encrypted when the information passes the CSS. In order to prevent the occurrence of this issue, configure the redirecting HREF on each server to point back to https at the same servers public address, not the VIP address, as shown here:
https://servers_own_ip_address/path"> secure site If your servers are in a private address space, configure SSL content rules for each server with a HREF on each server that points to the SSL Content rules VIP.
Below is the configuration example for your reference:
!Generated on 10/10/2001 18:12:17
!Active version: ap0500015s
configure
!************************** SERVICE**************************
service s1
ip address 10.10.1.101
active
service s2
ip address 10.10.1.102
active
!*************************** OWNER***************************
owner cookie-ssl
content layer5cookie
vip address 10.10.1.66
protocol tcp
port 80
url "/*"
advanced-balance arrowpoint-cookie
!--- Specify a port in the content rule to use this option.
!--- Port 80 traffic is used here.
!--- All clients must enable cookies on their browser.
add service s1
add service s2
active
content s1-ssl
vip address 10.10.1.88
protocol tcp
port 443
application ssl
add service s1
active
content s2-ssl
vip address 10.10.1.99
protocol tcp
port 443
application ssl
add service s2
active
!--- Use this HREF on server S1 where switching from http to https:
https://10.10.1.101/applicationpath1/"> secure site s1
!--- Use this HREF on server S2 where switching from http to https:
https://10.10.1.102/applicationpath2"> secure site s2
!--- In the example, the addresses for servers s1 and s2 must be
!--- reachable from the client. If this is not the case, you must add a
!--- content rule for each server with a unique publicly routable VIP
!--- address and one service for each SSL server, as shown here:
content s1-ssl
protocol tcp port 443
application ssl
add service s1
active
content s2-ssl
application ssl
add service s2
active
!--- Use this HREF on server s1 where the switch from http to https occurs:
https://10.10.1.88/applicationpath1/> secure site s1
!--- Use this HREF on server s2 where the switch from http to https occurs:
https://10.10.1.99/applicationpath2> secure site s2
Hope this will help you.
Here are the reference url:
http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_configuration_example09186a00801de8d6.shtml
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_example09186a008009450d.shtml
Here are the error messages we are getting from the websphere box:
[Wed Dec 03 12:23:47 2008] [info] [client 10.1.104.174] [963db0] SSL0230I: SSL Handshake Failed, An incorrectly formatted SSL message was received.
[Wed Dec 03 12:23:50 2008] [info] [client 205.189.14.52] [963db0] SSL0226I: SSL Handshake Failed, I/O error during handshake.
Also, we haven't seen this to be an issue in the past. Typically, we allow access via 443 the client types the https://vipaddress and everything works as expected.
The request is going to 1 of 3 JVM sessions running on the Websphere box.
you should capture a sniffer trace frontend and backend of the css to verify what is going on.
Your config looks alright.
Gilles.
