CME 7.0 and 7921G trouble
shawn.c.smith
Hello, I am new to this site but would like to dive right in. I have recently set up a CME 7.0 for use with a 7921 wireless phone. I can get the 7921 to register with the CME butit will not aquire the assigned DN and thus cannot make calls. Thanks for any help!!
16 Replies 16
Adrian Saavedra
Level 7
Level 7
Hi friend,
Could you paste your config?
- Adrián.
I am having the same issue with CME 7.0 which is used with cisco 7961 & 7941. they are registered with CME but not able to aquire the assigned DN and thus cannot make calls.
Can Any One Help Us in this Regards
Any help would be highly appreciated.
my 3825 router conf is attached:
Hello, I noticed on your config that ephone 1 and ephone 2 do not have button assognments. This would keep the phones from working. They should be assigned dn as below
ephone 1
mac-address 0023.331B.57CF
type 7961
button 1:1
ephone 2
mac-address 001F.CA4C.621F
type 7941
button 1:2
Hope this helps your trouble.
Hello, I have attached my 2821 config as well as a list of the files in flash. This is a lab router but I am troubleshooting an actual problem on a customer CME. Thanks for any assistance.
I have also noticed that when the phone is registered and I issue the show ephone 7921 command that the phone does not show as the correct ephone. Just a little more info. Thanks!!
Thanks a ton
now i'm able to dial my peer with extension
again im in trouble..
now not able to dial out..no dial tone
could you please help
Hi friend,
If you want to dial out, so you can make calls to PSTN, you need to configure dial-peers in your router.
Here is a guide to configure:
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dpeer_c.html
- Adrián.
I am not sure if your post regarding dial peers is in response to my original post or the replies by "netsoft@netsoft.co.in". The trouble I am having is that when the 7921 registers with CME it does not receive the assigned ephone-dn thus I cannot make any internal or external calls. Thanks again for any help in this matter.
Shawn
Thanks for the post but it doesnt helped me.I have 0 as secondary dial-tone. kindly tell what I need to configure to dial-out on any no.
Dial-Peer Configuration is attached.
Please Help
You need to add the port command on your POTS dial-peer to route calls properly to the PSTN thru PRI or FXO.
- Adrián.
Good Morning,
The problem with your Dial-Peers is most likley that there are no voice ports assigned to them. You must assign the voice port that is connected to the PSTN connection you are using. Below is an example. Good luck!
dial-peer voice 3 pots
description *****T1 PRI Pots Local Dial-peer*****
destination-pattern 9.......
port 0/0/0:23
dial-peer voice 4 pots
description *****T1 PRI Pots Long Distance Dial-peer*****
destination-pattern 91T
port 0/0/0:23
dial-peer voice 5 pots
description *****T1 PRI Pots International Dial-peer*****
destination-pattern 9011T
port 0/0/0:23
Actually the International dial-Peer is working fine.
dial-peer voice 96 pots
corlist incoming international-call
corlist outgoing international-call
destination-pattern 0.T
direct-inward-dial
port 0/0/0:0
but the local-call dial peer is not working calls are hitting to it but as I can see in debug its going with my secondary dialtone
example 09811111111
dial-peer voice 95 pots
corlist incoming local-call
corlist outgoing local-call
destination-pattern 09T
direct-inward-dial
port 0/0/0:0
dial-peer voice 94 pots
