Hunt Group Forwarding to External Phone
overbc01
We have a hunt line group that we would like to forward to external cell phones. Every time I dial the Pilot Number, the I receive the recording "Your Call Cannot be completed as dialed". The DN's are phantom phones that are all call forwarded to cell phones. If I take the forwarding off of the DNS then the call routes. Is it not possible to route calls off premise via a Hunt Group?
Jaime Valencia
call forward settings are not used when call is routed thru a pilot point or hunt pilot.
java
if this helps, please rate
java
Thank you. Do you know of any other way to route a number to a group of external cell phones?
the only possible way to do that is using the mobility feature to configure a mobile to ring along with the phone.
java
java
