Limit the number of clients per AP
Dec 3rd, 2008
Hi All,
I was wondering if there is a way to limit the number of clients to an AP? We run WLC's and a WCS. WLC version 4.1.185.0. I've read some stuff about threshold limits but nothing like "click this checkbox and enter in the max number of clients per AP" :>)
I've looked and have had no luck.
C
Jason Aarons Wed, 12/03/2008 - 17:54
  • Bronze, 100 points or more
If the clients use CCX extensions you can influence them. Search in the Wireless LAN Controller Configuration Guide for "Using the GUI to Configure CCX Client Roaming Parameters" and "Using the CLI to Configure Aggressive Load Balancing".
Examples;
(WLC) >config load-balancing win ndow ?
Number of clients (0 to 20)
5 In the Scan Threshold field, enter the minimum RSSI that is allowed before the client should roam to a
better access point. When the RSSI drops below the specified value, the client must be able to roam to a
better access point within the specified transition time. This parameter also provides a power-save
method to minimize the time that the client spends in active or passive scanning. For example, the client
can scan slowly when the RSSI is above the threshold and scan more rapidly when below the threshold.
Range: -70 to -77 dBm
Default: -72 dBm
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
