dial peers
Answered Question
Dec 3rd, 2008
i need some help, i cant seem to get my ccme to utilize my sip trunk for outgoing calls... i can receive incoming calls.
Correct Answer by Jaime Valencia about 8 years 4 months ago
configure a translation rule for calling number
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
vgioia5090 Fri, 12/05/2008 - 11:19
i can, but just another question because i think i have it figured out. it seemed that the 7940 was sending its extention numer instead of the did number assigned by the sip provider. how do i change that in config?
Correct Answer
Jaime Valencia Fri, 12/05/2008 - 13:11
  • Cisco Employee,
  • Hall of Fame,
    2011
java
