AsyncOS 6.5.0
Dec 3rd, 2008
Has anyone upgraded to AsyncOS 6.5.0 from 6.4.0 ??
If so, have you seen any issues with the upgrade?
*Just looking for some feedback before we make the jump*
jparker32 Thu, 12/04/2008 - 11:50
have upgraded 2 boxes and had no problems, really like the different levels of access you can now have also the external authenication for users.
pvdberg00 Thu, 12/04/2008 - 12:26
I have done the upgrade on our test-systems. No problems with the upgrade.
Peter.
sinikuub_ironport Thu, 12/11/2008 - 09:31
I have upgraded both with no problems yet.
Ok, did also upgrade on C and M boxes and all went well.
jackytime_ironport Mon, 12/15/2008 - 03:25
I found a bug after upgrading. Quarantine view page cannot go freely. When I click next page or page xxx in Policy quarantine, it displays 'page not found'.
The customersupport replys it's bug, will be fixed soon. But I'm in trouble now, it's not convenient to type long url in browser url box.
karlyoun Tue, 12/16/2008 - 17:44
Jackytime
It sounds like you are talking about defect 46043. We will include a fix for this in the 6.5.1 maintenance release, which will be released in early January. In addition, we are looking at making a hot patch available sooner. This hot patch would fix this one defect, and be provisioned to customers that encounter the defect, so far a very small number.
Since you already have opened a case you will be notified when this patch is available.
Karl Young
Product Support Engineer
jackytime_ironport Mon, 12/22/2008 - 02:50
Thanks, kyoung
I encounter another problem. Performance seems decrease compare with 6.4.
Workqueue sometime deliver slowly, while the CPU and IO, memory is normal.
Custmersupport replys it's bug 46086 and suggest me skip scan some attachment type. I skip application/octet-stream, application/pdf, it seems good now but when I use mail-body scan queue still block occasionally.
The filter contains dictionary-match is easy to block workqueue. While the filter works well in Version 6.4.
ricardocanavate... Thu, 01/08/2009 - 08:24
Some problems, some incoming domains have not sent me emails, I don't know what happens.
Can someone help me?
I'll try open support ticket, thanks.
karlyoun Thu, 01/08/2009 - 14:53
Jackytime
We have released 6.5.1, which has fixes for both the URL problem and defect 46086. It's still in a limited release stage so it requires special provisioning.
Here is a link to the release announcment
http://preview.tinyurl.com/8okz37
I've gone ahead and provisioned all of your appliances for the upgrade, so you can do that whenever you are ready. If you encounter problems, contact Support right away, but please let me know if this resolves your issues.
Karl Young
ESA Product Support Engineer.
Thanks, kyoung
karlyoun Thu, 01/08/2009 - 14:57
Ricardo
Probably a support ticket is the way to go. If you want to ask for help on IronPort Nation, I'd suggest you start a new topic, and include some more details about what the problem is.
prash_ironport Fri, 01/30/2009 - 05:33
Hi Kyoung,
we have upgraded to 6.5.1 and faced one of the defects. If the appliance is already under heavy load and tries to footer-stamp a heavy mail, it pauses the entire workqueue.
We were advised by Support to exclude heavy messages from being footer-stamped (disclaimer).
Also, 6.5.1 still does not support html disclaimers - something which has been requested by many customers. Why so? (Myself waiting for almost 10 months).
karlyoun Fri, 01/30/2009 - 14:15
Hi Kyoung,
I'm aware of this defect. It is not new to 6.5.1. The problem is that in order to add a footer to a message, we have to make a copy of it in memory. If memory is limited, and the message is very large, this can cause problems. This was reported quite a while ago, but there have been almost no reports of customers seeing it, so it was never addressed.
Recently we looked at it again, based on a new customer sighting (I assume this was you), and have assigned an engineer to look into possible solutions.
Unfortunately, we have to prioritize feature requests. We'd love to implement them all, but we can't.
prash_ironport Thu, 02/12/2009 - 05:14
Thanks Kyoung.
Is this the same for "html disclaimer"?
I am sure many customers have been waiting for this for long time now.
