12-03-2008 06:05 PM - edited 03-04-2019 12:35 AM
I am about to do a password recovery with my cisco 2800 series router, however, instead of command confreg 0x2142, I accidentally command confreg 0x2124. What should I do next? After I command "reset" it shows strange characters instead of the "#" sign. Pls. help. thanks...
Solved! Go to Solution.
12-03-2008 06:56 PM
This link will help you:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a008022493f.shtml
0x2124 change the speed of console port to 19200 instead of 9600.
Laurent.
12-03-2008 06:56 PM
Laurent.
12-03-2008 08:34 PM
thanks a million! it works!
12-04-2008 09:51 AM
You're welcome !!
Laurent.
