CVO question
Dec 3rd, 2008
Getting ready to design this solution and have a question about the equipment needed for the headend.
Everything I read says to use a router of somekind to be the termination point for the Home office 88x router.
Question: Will an ASA5510 work just as well?
carenas123 Tue, 12/09/2008 - 09:04
Yes you need to use the router. ASA 5510 is generally used for the adaptive security purpose.
chirag3737 Thu, 04/21/2011 - 08:56
Hello Richard,
Have you implemented this CVo in your enviornment? I am planning to preccess.
I have to plan the implement the CVO at our 30 offices.Do you guys suggets any idea how can I start and I already brought the 2 ACS and 2 3900 series routerr and 5 800 series CVO routers.
Is any ongoing issue to concern about this CVO project?
Anyone from cisco side give any suggestion.
Thank you,
Chirag Dobariya
